How can I solve this example with the Robot?
For isostatic vain 15m. of the figure, studying the effect of passing a load of 19.5 T
at speeds of 330 Km / h and 288 km / h. Use a maximum of 10 elements flat bar
in the discretization. We consider a modal damping factor of 2%.
Thank you very much for the responses received
Solved by Artur.Kosakowski. Go to Solution.
You may find this example helpful.
