Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Time History analysis and API
14 REPLIES 14
Message 1 of 15
880 Views, 14 Replies
Dear all,
For Robot Structural, I am trying to automatize Time History Analysis with VBA and API. The purpose is to model a running train at different speeds on a bridge.
I have found example of code to export THA results to Excel, but no example on how to code the THA load case and the time functions. The "Robot API.pdf" is sometimes difficult to understand and simple examples would be very useful and time saving. Are there code examples available?
Thank you in advance, Ivan Wouts
14 REPLIES 14
Message 2 of 15
Rafal.Gaweda
       Dim r As New RobotOM.RobotApplication
        Dim sc As RobotOM.RobotSimpleCase
        sc = r.Project.Structure.Cases.CreateSimple(2, "time", RobotOM.IRobotCaseNature.I_CN_EXPLOATATION, RobotOM.IRobotCaseAnalizeType.I_CAT_TIME_HISTORY)
        Dim thfl As RobotOM.RobotTimeHistoryFunctionList
        thfl = r.Project.Structure.Cases.TimeHistoryFunctions
        Dim thpc As RobotOM.RobotTimeHistoryPointsCollection
        thpc = thfl.Create()
        thpc.Add(0, 0)
        thpc.Add(1, 1)
        thpc.Add(2, 0)
        thfl.Store("a_function", thpc)
        Dim p As RobotOM.RobotTimeHistoryAnalysisParams
        p = sc.GetAnalysisParams()
        p.Set(-1, "a_function", 1, 1)
        sc.SetAnalysisParams(p)
 Another example attached
Rafal Gaweda
Message 3 of 15
in reply to: Rafal.Gaweda
Thank you very much for your prompt answer. It is much appreciated.
Message 4 of 15
jkn
Hi Rafal
I am looking into the excel file THA creationex and getting an error, when trying to use it.
Could you maybe attach a robot-file, where the excel/vba code work on, so I can figure out, where the error in my file is?
The error is
Run-time error '-2147467259 (80004005)':
Method 'Get' of object 'IRobotTimehistoryAnalysisParams' failed
Best Regards
Jakob Nielsen
Message 5 of 15
jkn
in reply to: jkn
Hi Rafal
And maybe also a Robot-file where the "Time history point collection" code works in.
Best Regards
Jakob Nielsen
Message 6 of 15
Rafal.Gaweda
in reply to: jkn
Example attached.
Rafal Gaweda
Message 7 of 15
jkn
Thank you very much.
Message 8 of 15
jkn
Hi Rafal
I am trying to use the code, where you are making a pointcollection.
But am getting an error at the following line
"thpc.Add(0,0)"
If you get the time, please send an example?
Best Regards
Jakob
Message 9 of 15
marcinrakus
in reply to: jkn
If You are using VBA try without brackets.
Regrads,
Marcin
Message 10 of 15
jkn
in reply to: marcinrakus
Thanks!
That helped.
But now I get another error
"Object variable or With block not set"
This line is highlighted in the vba code
Sub test()
        thpc.Add 0, 0
        thpc.Add 1, 1
        thpc.Add 2, 0
        thfl.Store "a_function", thpc
        p.Set -1, "a_function", 1, 1
        sc.SetAnalysisParams (p)
End Sub
Best Regards
Jakob
Message 11 of 15
marcinrakus
in reply to: jkn
In VBA in front of every variable that is an object You have to write Set.
So, in Your case it would be:
Set sc = r.Project.Structure.Cases.CreateSimple(2, "time", RobotOM.IRobotCaseNature.I_CN_EXPLOATATION, RobotOM.IRobotCaseAnalizeType.I_CAT_TIME_HISTORY)
Marcin
Message 12 of 15
jkn
Thanks a bunch!
Message 13 of 15
SPadID02
Hi Rafal
Would it be possible to get these results using the results query approach to speed up the process?
I am trying to tweak your code from this post https://forums.autodesk.com/t5/robot-structural-analysis-forum/api-is-there-a-way-to-get-results-fas...  but in the process of trying to run the original I am getting a 'Class not registered' error for
Res = RobApp.Project.Structure.Results.Query(RobResQueryParams, RobResRowSet)
which appears to be in relation to the 'RobResRowSet' part and so before I try to fix this error I want to make sure it is a possibility.
Of course if it is possible any code adjustments would be much appreciated! And also a fix for the Class error but I have seen a few posts for similar issues so will try those.
Message 14 of 15
Rafal.Gaweda
in reply to: SPadID02
Hi @SPadID02
Results.Query is only 64bit service.
Compile  \ build your app as (with) 64 bit app \ dll.
Rafal Gaweda
Message 15 of 15
fareed12
Is possible to calculate Torsional Amplification factor (Ax ) by dynamic forces from (Response Spectrum Analysis) or need to make procedures to do it?
