Discussion Groups
Robot Structural Analysis
Active Contributor
0 Kudos
Timber structures - Accidental combinations
144 Views, 1 Replies
10-27-2011 06:57 AM
New timber question:
When defining load combinations I can define accidental combinations.
But when doing calculations for timber members you can only choose Servicability and Ultimate limit states.
How do I perform code-checks for timber structures for accidental load combinations?
Product Support
757 Kudos
Re: Timber structures - Accidental combinations
10-27-2011 07:17 AM in reply to: Hallvard
In exactly the same way as for 'standard' ULS combinations. Just type their numbers in the list field and mark the Ultimate check box in the Calculations dialog.
Artur Kosakowski
