Discussion Groups
Robot Structural Analysis
Product Support
Artur.Kosakowski
Re: Timber frame
01-10-2013 04:03 AM in reply to: sj352
 How can I make sure that the beams carry the slab and not the other way around?
I would check the deformation of the model. If the beam deforms as a 'whole' then the influence of beam is small or any. If you have 'separate' deflections in each of the fields then beams support the slab.
Artur Kosakowski
Please use plain text.
sj352
Re: Timber frame
01-10-2013 04:05 AM in reply to: sj352
Will I do by "offsetting" beams under the slab?
Product Support
Artur.Kosakowski
Re: Timber frame
01-10-2013 04:12 AM in reply to: sj352
Yes, this will 'increase' the stiffness of the beams.
Artur Kosakowski
