Discussion Groups
Robot Structural Analysis
Active Contributor
Hallvard
Timber columns - Initial deflection
198 Views, 3 Replies
10-25-2011 11:01 PM
Hi
Im working on a timber frame structure.
When doing member definitions for timber columns I would like to apply a initial deflection. In practice all columns are not perfectly linear, and to the eccentricity will give a moment.
How can I apply this initial deflection of columns?
- Hallvard
Please use plain text.
Product Support
Artur.Kosakowski
Re: Timber columns - Initial deflection
10-25-2011 11:47 PM in reply to: Hallvard
You can use the geometrical imperfection as shown on the attached picture.
Artur Kosakowski
Active Contributor
Hallvard
10-26-2011 06:53 AM in reply to: Artur.Kosakowski
When using the Imperfection definition and "user defined" I have set e0 to 0,0025*L.
When I open this dialog again e0 is 0,00*L
I guess this means that e0 still is 0,0025*L, but all decimals are not showing.
Correct?
Product Support
Artur.Kosakowski
10-26-2011 07:01 AM in reply to: Hallvard
Correct. You can check after changing the display format for the corresponding units in Job Preferences.
Artur Kosakowski
