Hy folks, i've just tried to perform thick steel plate buckling analysis, during calculations a masage appiears " no elements under compression! <...>, nethertheless structure is loaded. Could anyone explane me, why is it so, please?
Solved by Artur.Kosakowski. Go to Solution.
What kind of buckling deformation would you expect for such axisymmetric structure?
Then define it as a shell model instead
