I have assembled the attached file as a time history, using the same principle as a seismic time history I recently used. The history denotes time (in seconds, left column) and wind speed (m/s right column). I was hoping to apply a factor on the history in Robot to transform it into a force, but can't get the history to read in. Have I assembled the .thf file correctly? When I 'open from file' in the history definition nothing appears!
I have had to change the file extension to .txt to allow me to upload - I have this as .thf when I try to use it in Robot.
Solved by Rafal.Gaweda. Go to Solution.
Function keyword must be in capital letters
Enter must be pressed after last line
Corrected file attached
Thankyou Rafael, I see the format of the text was the problem. I will no doubt have some questions about applying the load but will review the forum posts before I ask.
Stefan - can you explain further your comments regarding the units?
Please can you explain this converting method from txt file to thf file in detail. I did everything (Capital letter FUNCTION, second line function name, third line row number, and columns) Still my file is txt file. I couldnt change it. Please help me.
Hi @msu-bekinci , it's much much more easy than you think. Simply type filename "*.thf"
Cheers
You mean I dont need to do all these steps (FUNCTION, FUNCTION NAME, ROW NUMBER)? Is it enough to change the file name as .thf only ?
