I get the following message when trying to run calculations for my model.
"The load has not been distributed correctly..."
I have two models. The first model was correct, and calculations ran fine, but after alterating some panels, it all went wrong. I get the warning only for new panels, the ones from the old model are calculated correctly I guess.
Solved by Artur.Kosakowski. Go to Solution.
You have defined loads with no values - delete or correct them.
