Discussion Groups
Robot Structural Analysis
Distinguished Contributor
mateaus
Text file error
303 Views, 13 Replies
11-08-2011 09:25 AM
Hi I have a problem with my text file I send in attachment.
It's saying : "Pas d'exemple"
It's doesn't work. Can you have a look ?
Please use plain text.
Product Support
jad.dellel
Re: Text file error
11-09-2011 12:09 AM in reply to: mateaus
this article should help you:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=16577994&linkID=12305695
Regards.
Jad DELLEL
Structural Engineering Support Autodesk, Inc.
mateaus
Re: Text file error
11-09-2011 01:08 AM in reply to: jad.dellel
Ok I have found the solution. But I would like to give a number for my slabs (plaques).
MAI
  DOM 8 11
1
29
30
2
NUMerotation ELEments 100 ' It's not working ! the number in the model is 15
MAI FIN
 This text is not working. In the model the number of the slab is automatic, I would like to give a number myself.
How can I do ?
Product Support
jad.dellel
Re: Text file error
11-09-2011 01:53 AM in reply to: mateaus
The description of French syntax of STR text file is contained in R97mod33.doc file attached should help you.
But it is important to know that STR text file is no longer developed and it does not support many features supported by  the RTD file  (For example panels and meshing of them, code design paramaters, etc.)
Jad DELLEL
mateaus
Re: Text file error
11-09-2011 02:19 AM in reply to: jad.dellel
Yes I know that but It's too complicated to use VBA for Robot.
That's why I use text file until I have a training for it.
I send my text file.
Could you have a look please in order to define the number of slab elements ?
See lines after ";plaques"
Product Support
jad.dellel
Re: Text file error
11-09-2011 02:51 AM in reply to: mateaus
The file attached wasn't VBA code, It's only the syntax to respect to have a valid text file.
I'll check your text file.
Jad DELLEL
mateaus
Re: Text file error
11-09-2011 02:55 AM in reply to: jad.dellel
Yes it's a text file.
Product Support
jad.dellel
Re: Text file error
11-09-2011 05:13 AM in reply to: mateaus
You've used the syntax " NUMerotation ELEments 100" this syntax enables to control the starting of generated finite elements, but unfortunately It is not impossible to control numbers of panels in text file they're numbered automatically.
If you delete this block, I mean " NUMerotation ELEments 100" , you can get the rtd file (see file attached).
Jad DELLEL
mateaus
Re: Text file error
11-09-2011 05:46 AM in reply to: jad.dellel
I think it's possible :
In the R97mod33.doc file it's written :
(NUMérotation ELEments <no_base_éléments> NOEuds <no_base_noeuds>)
How can I use it ?
My problem is that I want to define the thickness of the panel like
100 EP=0.2
But I don't have any number of panels to affect.
Maybe I don't use the correct method, have you got a solution ?
mateaus
Re: Text file error
11-09-2011 08:16 AM in reply to: mateaus
It's working if I affect the thickness to the mesh of the panel :
NUMérotation ELEments 101
CAR
"BETON35"
 100 A 591 EP=0.2
but in the robot application you canot see the characteristics of the panel.
