Why robot use compression force in bars like a positive value and tension as a negative? Is it possible to change in some further versions and add to wishlist?
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/sign-convection-of-truss-forces/td-p/3769603 - message 2
This limitation is very frustrating. I'd like to decide what is positive or negative.
And I'd like to change the colors too. Is that already possible? thanks
Not possible
Possible:
Thanks Rafal!
Will it ever be possibile to change what is positive or negative? My clients use the opposite notation as robot and they never understand my graphs
For now, which is the best and fastet workaround to change the graphic results?
Thanks!
For now, not planned
Thanks, I could change the blue, but I still cannot change the yellow.. Is that possible?
I'm looking for a workaround to mirror the results of tension and compression.. Do you know one?
Table results, copy \ export to Excel, change sign there
Now if there's a way to re-imput those values in robot and create a new "correct" diagram that'll be awesome!
Nice joke 🙂
