Hi all
please help me for create a tempalate for robot?? use metric unit?? or template of russia?
Thank all
yes thank you
I using metric unit,this template must intergrate with asd , rst??
please tutorial for me
thank you
Robot:
Use predefined set:
or adjust job prefences by your own and save as a defaults (example below, set codes additionally)
ASD:
use predefined
or set Job Preferences by your own and save as dwt file and select this saved dwt file in Preferences
RST:
yes thank you very much
I'm from vietnam
I using template of russia, i want you tutorial for me: step by step create template of robot??
I'm from vietnam
I know
Movie: http://screencast.com/t/B2qHet2Ax4
hi thank you so much
I do not know much English, hope you understand
I hope you can share me the movie that guide the robot is not?
thank you
In french maybe or use translate.google.com from vietnamese to english
hi yes I used translate.google.com
can you share for me: document or video tutorial teach robot??
hi Please thank
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Documentation-about-Robot-SA/td-p/3533884
hi thank You very much
in Vietnam is very little documentation and manuals
I also refer to the documentation on autodesk.com but it's hard not apply and details
hope you share and help
