Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
tapered column section
3 REPLIES 3
peter-rc
955 Views, 3 Replies
hi,
is there any way to create tepared concrete column section?
thanks
3 REPLIES 3
Artur.Kosakowski
in reply to: peter-rc
If you want to use it in the model for static calculations of a model then there is no problem (you can define a steel section and then change material of a bar in the model) but such sections are not supported for in the RC Column Design module.
Artur Kosakowski
what about dynamic calculations ?
As for static analysis.
Artur Kosakowski
