tapered column section
3 REPLIES 3
965 Views, 3 Replies
hi,
is there any way to create tepared concrete column section?
thanks
3 REPLIES 3
Artur.Kosakowski
If you want to use it in the model for static calculations of a model then there is no problem (you can define a steel section and then change material of a bar in the model) but such sections are not supported for in the RC Column Design module.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
what about dynamic calculations ?
As for static analysis.
Artur Kosakowski
