Tables - Sum of values
7 REPLIES 7
Message 1 of 8
AlexDT
2887 Views, 7 Replies
What does "sum of val", "check val" precision mean? What does it show?
Does Sum val(ue) give me the sum of forces responsable for the reactions?
7 REPLIES 7
Message 2 of 8
Rafal.Gaweda
in reply to: AlexDT
Message 3 of 8
AlexDT
in reply to: Rafal.Gaweda
Thanks! Sum of value is still not very clear to me though.
"Sum of val. - An arithmetic sum of values of forces and moments for a given direction for the currently-filtered nodes."
Sum of what values and which direction?
Message 4 of 8
Rafal.Gaweda
in reply to: AlexDT
Take a look below:
- selection in green
- direction = columns (yellow, blue)
Rafal Gaweda
Message 5 of 8
AlexDT
Thanks. It is simply the total of the reactions of the selected nodes then?
In my case I selected all the nodes, but the the sum of value for the moments are not  equal to the sum of forces.
In fact I changed all my supports to pinned so I didnt have any moments in them, but the sum of reaction for those nodes still remain? I dont get how that adds up.
Message 6 of 8
Rafal.Gaweda
in reply to: AlexDT
So either you have elastic supports  \ ground on model or you are looking on nonconverged results of nonlinear case.
Example below
Rafal Gaweda
Message 7 of 8
from the RSA Help it is stated that :
"In quadratic combinations for cases of the seismic or spectral analysis, the sum of reactions and the sum of forces are calculated by adding the values of the respective sum of values and the sum of forces for individual vibration modes"
Can we have a little more explanation ie : the somme of reactions are equal to ....
and the somme of forces are to....
in this case (quadratic combination) the "somme of values" have no signification ( it still just a arithmetic somme below)
Thank you
Message 8 of 8
It is answered in the mesage 2 of this post:
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Reaction-Table-query/m-p/3949469#M14317
Pawel Pulak
Technical Account Specialist
