Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Table saving missing path
1 REPLY 1
rioja
256 Views, 1 Reply
Hi all
From the steel design table, is there any posibility to save the results as .cvs ?
1          How to specify a folder to save the results from ARSA?
You will find in the second file, the diference between the buttons in the shorter list it is no more available the button "Change"
Thanks a lot in advance
1 REPLY 1
Artur.Kosakowski
in reply to: rioja
1. Change is for the selected 'line' only.
2. This is a label rather than a path Smiley Happy Intended for the printout composition.
3. Save in Word and then copy via clipboard to Excel
Artur Kosakowski
