Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Table of Nodal Displacements for each Mode
3 REPLIES 3
753 Views, 3 Replies
Does anyone know if it is possible to extract a table from Robot which provides the displacement of each node for each mode shape when undertaking a modal analysis?
STL
Tags (1)
3 REPLIES 3
With all respect I think you may have misunderstood the type of results available from a modal analysis.
Modal analysis results in "normalised" deflections/displacements, and as such the number reported is not an "actual" deflection.  If you ran a spectral analysis (for example) then you could take the deflections / displacements at face value.
Tony
Artur.Kosakowski
As Tony wrote these are not real displacements but the 'numbers' are available in the dynamic analysis result table (use RMB to mark the appropriate columns).
Artur Kosakowski
in reply to: Artur.Kosakowski
Tony Artur,
Many thanks for your replies. Tony, you are right I was misunderstanding the results. Artur, I think your attachment is what I was looking for.
Many thnaks
STL
