TABLE FILTER
4 REPLIES 4
StefanoPasquini6790
352 Views, 4 Replies
TABLE FILTER
Hi group members,
Anyone of you know the reason why the filter for the selection of tables doesn't works on Robot 2013? For example, if I select two beams and ask for the table of forces only on them, Robot returns the table of forces for all the bars of the structure. Is this a bug for the 2013 version? Is there some setting to do?
PasProStudio
www.pasquiniprogetti.eu
Structural + Detailing engineers
4 REPLIES 4
It works like that: http://screencast.com/t/Q3TH4FuQk
Rafal Gaweda
Hi Rafal,
i perfectly know how to use this command, I'm a Robot user since version 17.5. I only pointed out that on my PC, with   the 2013 version installed, this function does not work...as in the previous version...
Regards
PasProStudio
clear windows %temp% folder , clear  cfgusr folder before next robot start
Rafal Gaweda
Thanks for your suggestion, i've removed only the *.tbl files in the cfgusr folder, and everything it work correctly. When i clear all the content of the cfgusr folder i lose all the personalization for command, keyboard, visualization and much much more...
Thk
PasProStudio
