Morning,
I have manually insterted the load factors into the load combination table for the ULS checks.
Is there a quick way of checking serviciability limit state (SLS) deflections without having to adjust all the load factors for each combination to 1.0?
Steve
Solved by Rafal.Gaweda. Go to Solution.
Use automatic code combiantion generator to generate SLS combinations or you may try this macro:
