I am using RSA 2015 SP1, and I noticed in one of the new models I am doing that the surface loads on complex panels are applied only in one directions (local axis) regardles the local Z direction.
How can I overcome this bug and move on please?
I hope I don't have to wait to the next SP !!
I am mainly concerned in applying hydrostatic load, but even with uniform loads it does not work.
Solved by Rafal.Gaweda. Go to Solution.
I usually use a standard panel in my models, but in this case, how do you recommend modelling this panel without going to ACIS?
this is supposed to be an inclined wall of a box with two pipes welded to it, so the intersecting surface is an oval shape. in order to get the pipe mesh and the panel mesh intersect, I had to use the object combinations, inclusion and cut to make it work. once I do that then my RSA change the panel to ACIS object.
Any ideas!?
