Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Surface loads on complex panel Bug
6 REPLIES 6
mgaafar
577 Views, 6 Replies
          I am using RSA 2015 SP1, and I noticed in one of the new models I am doing that the surface loads on complex panels are applied only in one directions (local axis) regardles the local Z direction.
How can I overcome this bug and move on please?
I hope I don't have to wait to the next SP !!
I am mainly concerned in applying hydrostatic load, but even with uniform loads it does not work.
6 REPLIES 6
Rafal.Gaweda
in reply to: mgaafar
Do not use ACIS objects.
On standard panels it works fine.
Rafal Gaweda
mgaafar
in reply to: Rafal.Gaweda
I usually use a standard panel in my models, but in this case, how do you recommend modelling this panel without going to ACIS?
this is supposed to be an inclined wall of a box with two pipes welded to it, so the intersecting surface is an oval shape. in order to get the pipe mesh and the panel mesh intersect, I had to use the object combinations, inclusion and cut to make it work. once I do that then my RSA change the panel to ACIS object.
Any ideas!?
Rafal.Gaweda
Workaround available in Robot 2015:
Rafal Gaweda
t.sautierr
Rafal, which program do you use to have the mouse and the keys you press on the keyboard appearing on the video? Thx
Rafal.Gaweda
in reply to: t.sautierr
Righ top corner of movie -> Project Chronicle
https://chronicle.autodesk.com/
Rafal Gaweda
mgaafar
Thanks Rafal!!
