Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
support orientation
11 REPLIES 11
Message 1 of 12
byron86
453 Views, 11 Replies
support orientation
Hi, my pin supports are orientated in the z direction but should in my case be in the y direction.  It shouldnt affect my model, however I didnt notice I needed to change my direction for the mass of the tunnel and was acting like a side node.
So in summary, can I change the orientation, its bugging me.
Also, how can one check the sum of all the forces in the model. for a solid element.   The reactions table shows all the separate nodal reactions but not the total.
Regards
11 REPLIES 11
Message 2 of 12
HoshangMustafa
in reply to: byron86
Hi
You change support definition. Please find attached file.
Message 3 of 12
Artur.Kosakowski
Artur Kosakowski
Message 4 of 12
byron86
in reply to: Artur.Kosakowski
Message 5 of 12
byron86
I thought that was where to check but then I have a problem. The live load sum of forces is incorrect. The load is 4200kpa, 0.2x3.5 area. therefore total should be 2940.
Am I missing Something
Message 6 of 12
Artur.Kosakowski
Attach the file please.
Artur Kosakowski
Message 7 of 12
byron86
here it is.
Message 8 of 12
byron86
how do I reduce its size
Message 9 of 12
byron86
uploading it on 4shared
Message 10 of 12
byron86
Message 11 of 12
byron86
A linear 2 point load gives the correct sum of forces.  Not preferable though to use this
Message 12 of 12
Artur.Kosakowski
Artur Kosakowski
