Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
support of beam
20 REPLIES 20
Message 1 of 21
faisal.aaouatif
969 Views, 20 Replies
support of beam
Please take o look to the attachement above and tell me how can i resolve the pb.
thank you.
note : beams were calculated and exported from RSA2013 to beams module 2013.
20 REPLIES 20
Message 2 of 21
PLease send us this model.
Rafal Gaweda
Message 3 of 21
big model ...
way to send it please.
thx
Message 4 of 21
www.wetransfer.com
www.filemail.com
or ftp
Rafal Gaweda
Message 5 of 21
ok
sent by wetransfer.com to mailer@lithium.com.
thanks
Message 6 of 21
Send it to you and copy link to file into forum post or send me by Private Message.
Rafal Gaweda
Message 7 of 21
Message 8 of 21
in reply to: faisal.aaouatif
file of you erro.
See picture
Message 9 of 21
Rafal.Gaweda
A.wikipedia wrote:
file of you erro.
See picture
Download again. Fiel size should be 268 198 650
Rafal Gaweda
Message 10 of 21
ok
i used Ftp site as per demand on private mail.
hope it works now.
Thank you
Message 11 of 21
I got the file. Checking it.
Rafal Gaweda
Message 12 of 21
Rafal.Gaweda
in reply to: Rafal.Gaweda
Lack of supports on drawings is caused by supporting beams by panels \ walls.
Workaround here (applying elastic support with very low kz but correct size = panel thickness) : http://screencast.com/t/VykkkP4rc5
Rafal Gaweda
Message 13 of 21
Ok Rafal
Thank you.
ive noticed that workflow between RSA and  beams reinforcement module (may be with other reinforcement module too) is not  very smooth as it should be .... (should rename beams after export , Pb with reinforcement shapes ... )
i hope that efforts will be done in this direction.
Thank you
Message 14 of 21
Hi Faisal, I agree with you.
I believe that future is BIM, and it starts with architectural project, then we will module in Revit Structure, then send to Robot and to ASD to final drawings and detailings.
Nowadays, it has been easier to import a 2D drawings to Robot and do everying there ... but it doesn't make sense, it goes against to our "desired productivity".
 Rafal and Artur, it would be great if the transition, transformation, from a 3D project (Revit) would be smoother than today. It would be a competitive advantage for Autodesk and for us ...
Message 15 of 21
Same Problem of lack of support when having beams connected between them.( beams support of another one)
if doing the same trick as with a panel ( see above ) , the support added is concidered for both of two beams.
is there anyway to avoid this problem too.
thx
Message 16 of 21
Thanks Faisal
Message 17 of 21
So if you  have revit files not properly transfered to robot please send them us.
Real users' model are welcome to be checked.
Rafal Gaweda
Message 18 of 21
What is your situation in model?
IN my simple test example it works: http://screencast.com/t/LybyCykAlyp
Rafal Gaweda
Message 19 of 21
the calculation of beams in this situation are ok ( supports are took ito account ) but the problem is rised when generating drawing ( same pb when support are panels mentionned above). - See attachement please.
thx
Message 20 of 21
This issue is known, planned to be corrected.
Rafal Gaweda
