I am trying to model a curved panel in finite elements. To make things more simple, I've made a discrete polyline of this curve and then made the panel from an extrusion of this polyline.
I am then trying to put support nodes on this panel. The nodes are created by intersecting horizontal lines at the right height and the polyline (edge of the extrusion), so their coordinates have to be just right inside the plane of the panels.
My problem is that when I generated the mesh (Delaunay + Kang with refined mesh on support nodes and emitters), the previously created nodes are not taken into the mesh.
I guess that's a problem of tolerance, but I can't figure a way to force these nodes to be considered into the mesh.
Thanks.
Regards.
Solved by Rafal.Gaweda. Go to Solution.
