Hi
Please find the attached file. It would be of great importance if ARSA could label supports so that one can get a plan of foundations easily without need of drawing it with AutoCAD. Instead the designer should draw a plan of foundations.
Solved by Artur.Kosakowski. Go to Solution.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
