I am modelling a concrete base slab for a silo which is supported on 400SQ piles. The piles are modelled as elastic spring supports. When I define the pile/column dimensions in the advanced support definition there seems to be no change in the peak moments if I chenge between nodal support and column support options. I would expect the peaks to be smoothed out and reduced using the column dimensions. Is this correct in the robot model? I have attached screenshots and my model.
Enda
Solved by Artur.Kosakowski. Go to Solution.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
