Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Sum of harmonic loads - square rod of the sum of squares
2 REPLIES 2
zhurukhin
402 Views, 2 Replies
Hi!
I have static loads (#1 to #13 on attached picture) and harmonic loads (#15 to #17).
Is it possible in Robot to generate Automatic Combination, where the sum of harmonic loads will be calculated as the square root of the sum of squares:
Wp3 = √[(#15)^2+(#16)^2+(#17)^2]
Thank you in advance!
2 REPLIES 2
Romanich
in reply to: zhurukhin
Hi, maybe this help you:
http://docs.autodesk.com/RSA/2012/ENU/filesROBOT/GUID-DE72846B-F26F-4DA1-935D-F2A737E1FD9-583.htm
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
zhurukhin
in reply to: Romanich
Hi, Romanich!
Thank you for reply! It looks like the answer I need...
But is it possible to use this Quadratic Combination at the same time with Automatic Combinations?
I meen that this CQC will be as one of the loads in the table of combinations, generated automatically.
As far as I remember, we can use either Manual or Automatic...
