Is it possible to call the equivalent of 'edit substructure in new view' through the API based on the current selection?
Solved by Rafal.Gaweda. Go to Solution.
Hi
You have to create new view like this :
Dim viewRobot As IRobotView3 ' this is important to set IRobotView3 if you want to make screen capture of this view
' Set viewRobot = RobApp.Project.ViewMngr.CreateView(1)
Set viewRobot = RobApp.Project.ViewMngr.GetView(1) ' it seems CreateView makes this strange affect, use GetView instead
viewRobot.Redraw (True)
viewRobot.Visible = True
viewRobot.Selection.Get(I_OT_BAR).FromText ("1 2 3 4 5") ' selecting bars
viewRobot.Selection.Get(I_OT_CASE).FromText ("1") ' selecting case
viewRobot.Redraw (0)
