Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Structure with really small period
6 REPLIES 6
TSOFA
329 Views, 6 Replies
Hi, I have a structure (like tower) which is a staircase and lift shaft. I designed the structure as you can see at the link bellow but it seems that the period is really small ( 0.74sec for the first mode and 0.54 for the second mode which activates 60% of the mass) for such a slender type of structure.
Does this seems right to you??
http://we.tl/lZjV9YdQGk
6 REPLIES 6
TSOFA
in reply to: TSOFA
I also added a slab foundation to the structure and I find that is very strange that for the same foundation (comb 16- seismic foundation) the base pressure is always possitive but at the results of the sattlements I have uplifting effects!!
Rafal.Gaweda
in reply to: TSOFA
Check , change local Z direction of this panel
Rafal Gaweda
TSOFA
in reply to: Rafal.Gaweda
of which panel?
Rafal.Gaweda
in reply to: TSOFA
" slab foundation to the structure "
Rafal Gaweda
dimogrec
in reply to: TSOFA
f1=1.36Hz seems ok to me for this kind of structure. In my opinion your structure has many bracings so it isn't so slender...
TSOFA
in reply to: dimogrec
can you explain the pressure- settlements results? they don't seem to match with each other
