Structure verification - The load has not been distributed correctly
3 REPLIES 3
jfmh
1412 Views, 3 Replies
Hi!
I have a problem in panels without FE. In the verification of the structure the following error occurs in some panels: "The load has not been distributed correctly. there are no objects or elements carrying the load overlap". I can not get understand this error.
The file is attached to be easier to understand the problem.
3 REPLIES 3
Artur.Kosakowski
in reply to: jfmh
1. Increase the tolerance to 2 mm
2. To distribute the load the cladding has to be supported either by panel edges or bars. You need to add dummy bars (or replace each of the two the vertical panels with two smaller with edges at this level) under claddings 912 and 913.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
jfmh
in reply to: Artur.Kosakowski
Thanks Artur
In relation to item 2, I get it and I resolved.
But in relation to item 1, when I insert a tolerance of 2 mm, a new warning appears : "Cohesion of the calculation model has been provided by definition of the kinematic constraints in incoherent points of the finite elements mesh". how can I fix the problem?
Artur.Kosakowski
in reply to: jfmh
