Hellow , i have structure 80m long. I have to separate it into 2 parts 40m and 40m . I already define the model .
Defining seismic loads has a trouble .Each part has its seismic loads .
How to define loads for each part to be in action in eccentricity 5% ?
Does RSA understand the 5% is for each part or for all the structure ?
I would suggest running seismic analysis for each of the models separately.
I have one raft for the whole structure ! i want to solve the raft for the total reactions .
Otherwise you may try the following:
1. Define self-weight for the part A only
2. Define modal analysis with the disregard density switched on; definition of eccentricities in real (rather than relative) values
3. Convert case from the point 1 into the mass assigned to modal case from the point 2
4. Define seismic analysis
5. Define self-weight for the part B only
6. Define modal analysis with the disregard density switched on; definition of eccentricities in real (rather than relative) values
7. Convert case from the point 5 into the mass assigned to modal case from the point 6
8. Define seismic analysis
and check the results with care.
Ok , i can do this but eccentricity from what ? from the edge of story or fron G(center of gravity) ?
Hi , Artur . I have donewhat you have said to me but , there is one force for one story as before . I want to define forces for each part . RSA read the G for 2 parts ! RSA doesn't read G for each part . How can i make what i want ?
The story table is not capable of displaying results independently for selected parts of a structure treating them as a separate models.
