Discussion Groups
Robot Structural Analysis
Active Contributor
RoboExploiter
Re: Structure Design - Steel Design - Compound Members
11-16-2011 10:30 PM in reply to: Artur.Kosakowski
Hi Artur,
Thanks for all your help.  I've certainly learnt a few new tricks.
I've used your suggestions from this post to create a complex model. (beam division option and the detailed correction tool).
The correct drawing model and detailed drawing model don't always seem to work, but for those few cases i just moved the nodes ( the ones causing the instability) manually.
In some cases the snap seems to get confused.
I found that the non-linear analysis can be changed to a linear analysis through the analysis>analysis type window.
If you still want to see my model send me a private message.
Thanks Again.
Please use plain text.
Product Support
Artur.Kosakowski
11-17-2011 01:15 AM in reply to: RoboExploiter
Only when it is set manually rather than caused by some 'non-linear' object defined in the model :smileywink:
If you solved all the issues then I'd rather try to focus on other cases that need our assistance (I hope you don't mind). In case there is still something to have a look at let me now please and I'll contact you using the private message.
Artur Kosakowski
Active Contributor
willjvizcaya
09-25-2012 09:33 AM in reply to: RoboExploiter
Hi, im kinda new with Robot Structural Detailing but i've manage to complete a few models. I have the same problem and read the discussion, i needed to model 2 attached IPE450 for a lifting model so i procceded to create a compound section and didnt work... i know there is the paralel modeling solution but i still dont get if Robot CANTcalculate compound sections that can be created in the compound section windows?.. so what are they for?..
PS: sorry for my english im from latin america...
Active Contributor
willjvizcaya
09-25-2012 09:46 AM in reply to: willjvizcaya
i just read the second post and is just what i needed.. my bad!! thx a lot!
Valued Contributor
huyxp
03-31-2013 02:11 AM in reply to: willjvizcaya
I don't know Stell section UB in robot?
please help me search steel UB?
tks all
Distinguished Contributor
dimogrec
03-31-2013 09:13 AM in reply to: huyxp
Hi huyxp,
you need to add the corresponding section database (British sections UKST)
Try Tools -> Job preferences -> Databases -> steel and timber db -> Adding new database to the list ... see picture
