Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Structure Design - Steel Design - Compound Members
15 REPLIES 15
Message 1 of 16
5897 Views, 15 Replies
I've created a model composed of steel waler beams, struts and runner beams.  As the anticipated forces are large, the structure demands struts in pairs, walers in pairs and runner beams in pairs.
After I've run the model and forces have been generated, i try to use the steel design module to check the elements, and i get this error message:
"Bars 1to31By .... have not been calculated because they are composed of sections not available in the current code."
The sections i've selected are available in the standard UKST database that comes built with robot.
Now the clue is that Robot has analysed the splays which are single sections (same size sections as the struts).
Therefore i think it is a question of Robot not being able to handle compound members.  Is that correct?  Can anyone share similar experiences?
If my understanding is correct, does anyone know of an addin or a spreadsheet with API that I can use to design compund elements given all the information available in Robot?
15 REPLIES 15
Message 2 of 16
Artur.Kosakowski
Could you send me the model please? Assuming that you set BS as the steel code the compound section built from two H sections should be supported.
Artur Kosakowski
Message 3 of 16
in reply to: Artur.Kosakowski
Hi Artur,
As requested.
Thanks.
Message 4 of 16
Artur.Kosakowski
The double H sections are supported provided they are really acting as a single profile (are welded along its contact edge) therefore you should modify the Waler section in the way shown on the attached picture. For the others you should make the change in the way you created your model and use two separate parallel bars each with a single UB section assigned instead of using the single bar with the compound section as it is now.
Artur Kosakowski
Message 5 of 16
Hi Artur,
I took on board your suggestion.  I've now modelled the waler beams and runner beams as welded together, and modelled the struts individually.
As the struts are not behaving as a single element anymore i've had to introduce lacing between the struts.  Making my model alot more complex.
I'm getting frustrated because the lacing i created did not snap to the centreline of the strut, resulting in microscopic gaps.
Why can't the snap tool, snap precisely to the centreline or the node?  Robot Mad
When I try to move the node back to the centreline it snaps to the other side of the centreline :'(
Is robot intelligent enough to analyse the members as being connected at the centroid, despite these tiny mismatches/gaps?
Message 6 of 16
Artur.Kosakowski
RoboExploiter wrote:
Hi Artur,
Putting aside the questions how to secure two H beams spaced by 1000 mm working together for horizontally applied load (imposed displacement) or torsion as well as for lateral buckling (unless they are prevented form it) when in the steel design module the load is not 'divided' into two sets and each of the two beams is not going to be analyzed separately - or in other words assuming that this set of beams works as a single compound beam you can 'force' Robot to design it. All you have to do is to create the section using the Section Builder module of Robot rather than the compound tab of the sections dialog. After calculating the properties of such created section you can save it to the user section database selecting its section type (the rules of the verification to be used by the Steel design module of Robot - see http://forums.autodesk.com/t5/Autodesk-Robot-Structural/How-to-create-thin-walled-sections/td-p/3107... ). The problem is what the section type to use (how this compound section is going to work in the model) - should it be a structural tube? Anyway as my intension is to show that such approach is possible as well I'm going to leave this particular question unanswered.
Perhaps you have too many snap types switched on at the same time. Perhaps the following approach will help:
1. Switch off display of grid
2. Generate auxiliary nodes along the beams using the Division option without dividing the bar itself
3. Use snap to nodes creating auxiliary bars
Otherwise you can correct the model using either the detailed correction option (see http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Warning-after-Structure-Verification/td-p/32... )
or after selection of nodes typing the values of coordinates in e,g. Inspector
Providing the inaccuracy is 'small enough' or within the default tolerance range - yes it is. Otherwise you can increase the tolerance (within the reasonable limit of course) Smiley Wink You can check if the calculation elements are created between the auxiliary nodes as explained in the http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Wind-crosses-and-and-DSC-algorithms/td-p/319... .
Hope this helps.
Artur Kosakowski
Message 7 of 16
The last attachment for the previous answer.
Artur Kosakowski
Message 8 of 16
Thanks for your suggestion on creating new user defined sections.  I might tinker with this at some point in the future.  The only problem that I foresee is that after design of the elements, if the structure is under capacity (or severely over capacity)  it won't be easy to swop in a new user defined beam, as I'd have to create it.
I took on board your suggestion to split up the beam using the division option.  It was tedious, but at least now its thorough.
"Otherwise you can correct the model using either the detailed correction option (see http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Warning-after-Structure-Verification/td-p/32... )"
I read this post you sent me but its not relevant to my problem.  The post title is "Warning after Structure Verification".  But my problem is about autocorrection of an inaccurate model.  Are you sure you gave me the right link?
"or after selection of nodes typing the values of coordinates in e,g. Inspector"
This is not as easy as it looks.  As you'll see in my model one wall in my model is inclined at 26 degrees to the other wall.  I've had to rely on Robots translation and rotation tools to create the model geometry.  Therefore some nodes might have positions defined to less than a mm.
"Providing the inaccuracy is 'small enough' or within the default tolerance range - yes it is. Otherwise you can increase the tolerance (within the reasonable limit of course) :smileywink:"
Ok, noted.
:smileywink: You can check if the calculation elements are created between the auxiliary nodes as explained in thehttp://forums.autodesk.com/t5/Autodesk-Robot-Structural/Wind-crosses-and-and-DSC-algorithms/td-p/319... ."
What auxillary nodes are you referring to?
Ok, so finally the entire model is looking like it should, and loaded like it should be. I hit the calculations button, and my model is not converging.
Firstly, I haven't specified my model to perform a non-linear analysis, so I don't know why Robot has chosen this method over a static calculation.  Secondly  I don't know how to change it back to a static analysis.  I've had this problem before with previous robot models, and the only way to circumvent this error is to start again.  Please, please tell me there is an easier way.
Message 9 of 16
Artur.Kosakowski
I'd say you are in the exactly the same position when you use the compound sections (the automatic search for the right size of the beam is done for the sections stored in the section databases). What you can do is to create a number of sections that you would consider as possible to be used for a particular model and save all of them in the user section database within the same family. Then you can use them in the design process in the same way as the standard sections.
Yes, I think so. The meshing.png picture I attached shows the described above functionality in the reference to this line: "You may start with the detail correct option and run it for the entire structure adjusting it to e.g. structural axis." I'm attaching this picture to this post as well. In your case the adjustment to the line may be what you need.
The rotation or translation tool should not influence the accuracy of the model. In addition for the functionality I described (use of the Inspector to correct the coordinates) you can set your local work plane by 3 points in such a way that a bar with nodes along it is length that is arbitrary located in the space is 'set' along the one of the main axes of the coordinate system. Then you can easily type the new value of the coordinate you want to change. I'm attaching the example of the use of this option for the graphical definition of the rotation angle (copy of the bar 1 by rotation it by the angle between bar 1 and bar 5).
I meant the nodes you defined along the bar (as if dividing it into parts) in order to connect it with the one next to it to secure these two bars work together (as if it was the compound section).
 Could you attach the model please?
Artur Kosakowski
Message 10 of 16
Artur.Kosakowski
Have you managed to solve all the issues with this model or is there anything I could help with?
Artur Kosakowski
Message 11 of 16
Hi Artur,
Thanks for all your help.  I've certainly learnt a few new tricks.
I've used your suggestions from this post to create a complex model. (beam division option and the detailed correction tool).
The correct drawing model and detailed drawing model don't always seem to work, but for those few cases i just moved the nodes ( the ones causing the instability) manually.
In some cases the snap seems to get confused.
I found that the non-linear analysis can be changed to a linear analysis through the analysis>analysis type window.
If you still want to see my model send me a private message.
Thanks Again.
Message 12 of 16
Artur.Kosakowski
Only when it is set manually rather than caused by some 'non-linear' object defined in the model Smiley Wink
If you solved all the issues then I'd rather try to focus on other cases that need our assistance (I hope you don't mind). In case there is still something to have a look at let me now please and I'll contact you using the private message.
Artur Kosakowski
Message 13 of 16
willjvizcaya
Hi, im kinda new with Robot Structural Detailing but i've manage to complete a few models. I have the same problem and read the discussion, i needed to model 2 attached IPE450 for a lifting model so i procceded to create a compound section and didnt work... i know there is the paralel modeling solution but i still dont get if Robot CANTcalculate compound sections that can be created in the compound section windows?.. so what are they for?..
PS: sorry for my english im from latin america...
Message 14 of 16
willjvizcaya
in reply to: willjvizcaya
i just read the second post and is just what i needed.. my bad!! thx a lot!
Message 15 of 16
huyxp
I don't know Stell section UB in robot?
please help me search steel UB?
tks all
Message 16 of 16
dimogrec
in reply to: huyxp
Hi huyxp,
you need to add the corresponding section database (British sections UKST)
Try Tools -> Job preferences -> Databases -> steel and timber db -> Adding new database to the list ... see picture
