Hi I am quite confused in interpreting the stress direction in solid stresses.
Direction XY, what direction is that? does that mean the new X axis is in the direction of τxy?
Some assistance would be appreciated.
Are you talking about Panel Stresses?
directions are local panel directions. xy are the torsional stresses
Hi sorry I was not clear, from the model below.. its a volumetric solid. Column is 1x1 section at a height of 10m, a load is applied to the top of 1000KN. So my greatest stresses I would expect is to be acting in the global y direction thus 60 Mpa, determining my moments from beam theory as is approximately 10000KNm, so Syy is the correct stress. The main stress is therefore Syy, however to me Syy locally is acting in the global z direction.
So im confused how Direction XY allows you to determine your local x axis, is that a plane or directed like similarly to Tau XY.
In summary im finding ity difficult interpreting which directions the stress are going. In this example I know Syy must be acting in tension and must be in the global Y direction, but in more difficult cases I get quite confused.
Thanks for the replies and help in advance.
Hello, Some assistance would be much appreciated.
I know in the help section it says " the direction is defined by entering any vector defining the main direction when selecting the results for surface FE" . So yes it uses Txy (basically the global y direction) as the new X axis?
As shown in the example, robot shows the same local coordinate system, however I would expect the main stress to be direction SXX..
Again any help is much appreciated
