Message 1 of 34
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Dear Colleagues
I have three spread foundation as shown in the attached capture. These foundations are connected by strap beam which have the same foundations’ height and rested directly on the ground.
I have modeled the case as shown in the capture (supports + beam with elastic modulus of subgrade).
Kindly, Could I know how to deal correctly with this case especially in the design calculation (the interaction between spread footings with continuous footing)?
Because , when I design the corner footing as a neighbor footing , I have gotten very large footing dimensions as its without strap beam .
Will be highly appreciated if you support your response with small video.
Thanks in advance
Refaat
