me, and few of my colleagues are having weird problem, in steel module some strange letters appears. See attached image.
I couldn't find this problem in the forum.
Solved by Artur.Kosakowski. Go to Solution.
What is the member name exactly?
Yes, that was the problem.
Robot gave them strange names for unknown reason.
Table > select Name column > delete names
After that Robot gives them numbered names.
That's the solution.
Thanks Artur!
