I am newish to robot and am testing some scenarios. I have created a volumetric 1x1 concrete column with a height of 10m. There is an edge load of 1000KNm/m applied at the top. The stresses calculated are quite strange at a max of 20Mpa, according to beam theory the corresponding moments are approximately 3050KNm, while I am expecting the moments to be in the range of 10 000KNm with a deviation of maybe 10-15%. But 3000KNm seems incorrect and very low.
Is my theory correct, any possible reasons for this variation??
Regards Byron
Perfect. Thank You.
An additional question, shouldnt I have recieved mesh warnings considering the massive differnce in moments determined.
Using the mesh arrangement as above I would get a max stress of 65Mpa and changing it dimensions of 0.5x0.5 changes it to 50 Mpa. The corresponding moments varies from 10800KNm to 8500KNm respectively.
So no warnings will be given, rather knowledge of finite meshing rules must be strictly obeyed.
Again thanks for the help.
