Discussion Groups
Robot Structural Analysis
stroxy
Strange values in Reactions table
234 Views, 3 Replies
12-15-2011 06:30 AM
I am noticing some strange values in my Reactions table as follows
  • In static load cases where only vertical loads are applied, I am finding reactions in the horizontal direction
  • There is quite a big discrepancy between sum of applied loads and sum of reactions
I have attached some snapshots of the Loads and Reactions Table.
The building has been modelled on piles with linear springs attached over the length of the pile.  I notice there are horizontal reactions in the springs decreasing towards the base of the pile.
Could it be the deflection of the piles under static loads is causing these horizontal reactions in the springs?
is that why the forces and reactions are not adding up?
Please use plain text.
Product Support
Rafal.Gaweda
Re: Strange values in Reactions table
12-15-2011 06:46 AM in reply to: stroxy
Tower Model?
Rafal Gaweda
stroxy
12-15-2011 08:08 AM in reply to: Rafal.Gaweda
Yes, the same model i sent you
Product Support
Rafal.Gaweda
12-15-2011 08:25 AM in reply to: stroxy
OK, we will check model
Rafal Gaweda
