Do not understand why in this table of the reactions, all static loads have a check equal to 0, while the modal analyzes show a check equal to the double of the reactions.
The actions have the same sign of the reactions.
How is this possible?
PS: Robot version 2013.
Solved by Rafal.Gaweda. Go to Solution.
Andrea,
if these are seismic or spectral load cases and dominating mode was not set for them then such effect is justified. The information about sign was lost in quadratic combinations so forces and reactions have the same sign.
Similar topics were discussed before.
If this post answers your question please click the "Accept as Solution" button. It will help everyone to find answer more quickly!
I attach the file: http://we.tl/4V7AWBgGd6
How do I know which is the dominant mode quickly?
And how can I assign it to a Robot?
I can not find the factor of participation of the masses in%.
Where can I find it?
Are you sure to use elastic supports for Dynamic analysis?
(if you block springs you will get 88% of massesin X dir in 1 mode and 77% masses in Y dir in 2 mode ; of course your decision)
Keep in mind that you have defined different modes filter for OBE-H and OBE-V+SMS cases
Screen shot above corresponds to OBE-H cases
For other ones different dominant mode numbers
See first screen shot.
