Hi Rafal,
In continuation of the above topic I would like to put query to you regarding the same problem.
I was getting the same problem while calculating my Shaft model. Though I got rid of the convergence problem but I had one new problem which is related to the presentation of result map. I am attaching the image below which I got atfer making those changes in the analysis type.
You can see the inappropriate presentation of the results on the base slab and also in the shaft wall. I dont know the reason for it. So kindly help me in this case.
Kindly let me know if you need more information about this model.
Regards
Virendra
