Hello - I've been working on a fairly simple steel framed model. RSA doesn't report any errors or unstabilities when it runs - but I am getting some very strange deflected shape outputs (even under self-weight).
I've modelled cross bracing to act as a diaphragm for lateral loads, and gravity loads are applied through one-way cladding elements.
Is there some fundamental error within this model that I have not been able to debug?
Edit: I am using RSA2015 with SP2
Thanks for the quick reply. Yes, I just double checked - I have sent the problematic file.
The deflections look correct for me under 'Exact deformation for bars' - what does it look like for you under 'Deformation'?
Attach the model with results saved with the 'problematic' results displayed as well as make the screen capture with the "complete" Robot viewer.
The file has been saved after running the calculations - hopefully the results are in the file. If not, is there a procedure to ensure this happens?
I haven't zipped the file this time - using 4shared instead.
http://www.4shared.com/file/sMR7YOPcce/Roof_and_6th_floor__reframe_en.html
Thanks!
The models (files) are different which can be seen when y e.g. check the total value of reactions for case 1 which explains why there is the difference between 'mine' and 'yours' results. The reason for the difference is in the assumption of the way the deformation diagram is created.
Please check: http://forums.autodesk.com/t5/Robot-Structural-Analysis/Exact-deformation-for-bars/m-p/4364810 (message 4).
You can also try to select all bars and then generate additional nodes in their centers. After calculating the model you will have 4 mm for deformation too.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
