On the storie table , Are the results ( efforts ) given at the bottom or at the center of gravity?
thank you
Solved by faisal.aaouatif. Go to Solution.
The answer in your question should be given in help topic:
http://docs.autodesk.com/RSA/2013/ENU/filesROBOT/GUID-890C3B44-F7EE-4BB1-8C39-19F445B5B94E.htm
but i think that this help topic isn't updated so the informations given in there are wrong.
In one SP of ARSA2012 (i don't remember exactly in which one) the way of calculating the reduced forces has been changed:
