I created storey heights after importing Autocad file as a background but all are flat on the ground floor as attached. Please how to I correct this. Note that this doesn't happen on a new project.
Best regards,
Aliyu A. Aziz
Solved by Rafal.Gaweda. Go to Solution.
I would suggest to start axes definition around 0 in GCS and in correct units
Thanks a lot. I forgot to specify the units of the imported Autocad file. Now everything works after setting consistent units.
Aziz
