Solved by Artur.Kosakowski. Go to Solution.
Hi
This means that the position where the first stirrup will be set. This data is input by you. So you can change it to other value (e,g, 5cm instead of 2m).
Ok , what about decrease the distance between stirrups in the first 2 meters ? how i can do it ? for seismic requirements you need to intensification the stirrups
Hi
You can use stirrup distribution. Please find the attached file.
yes i tried, but the software put two stirrups over each other
i want to edit distribution of stirrups , but the robot put a new stirrups with new hangers !! why ? how i can edit the original distribution ?
with all respect
thanks a lot , but my questions is the number of stirrups is 22 and this distribute from on side left or right !! this will give you intensification for stirrups from one side ! so what about other side , in reality there's symmetry in the distribution ??
Many thanks ... it's work ... could i ask small question ? i want to change angle of hook reinforcement but there's problem some bars done but others not ?
what is the correct way to do it ? and i want to ask is there's main bars shapes ? or it's just one ?
If you mean the one with no hooks on the left hand side then I think it is the anchorage loop rather than the top reinforcement.
