Hi everyone,
this post is related to unresolved problems with workstation video card with ARSA 2016. I have to let you know that this problems it never happened in previous versions of Robot.
The following screenshots show the problems. I attach also the model to make a deep investigation in this issue.
I have often ARSA crash, it can be related to a double monitor???
My video card is a NVidia Quadro FX1800.
Solved by StefanoPasquini6790. Go to Solution.
Have you sent any crash report? If yes, what was the email address you entered?
We are working on 2 monitors too with no such issues.
Hi Artur,
the email address was stefano@pasquiniprogetti.eu, but I didn't sent the report on each crash.
Cheers
I can confirm periodical black display during printout composition bug and almost always very, very slow selection bug eg. during selection bars and node for steel joint design.
Sometimes I have to wait few seconds after mouse operation to see if something was selected or not.
This bug is related to version 2016!!! - I don't know what was made in software programming code but it should be repaired ASAP.
Actually... for new projects I am returning to version 2015 and waiting for bug repair.
BTW
Video card is NVIDIA Quadro FX3600M...
Jerzy
I tried to do the settings in regedit as you suggested:
For the black screen I'd like to ask you to set as false (instead of true) the following registry:
HKEY_CURRENT_USER\Software\Autodesk\Structural\RSAPRO\<ver>\Viewer:
And now I can't tell you if this it works.
My "home made" solution to this problem is:
1) for black screen capture, if I play with the resolution of the image I can find the one that paste the correct image. I don't find the real rule, is only an iterative dirty method.....but it works;
2) for crashes I've installed the undated driver of my videocard but, unfortunately, I lost the graphic acceleration in ACAD and ASD, so this is not a perfect solution.
whaiting for patch, cheers
