Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Steel vs. Aluminium design
4 REPLIES 4
jo2ny
2545 Views, 4 Replies
Hi all,
I'm having trouble designing a beam made of aluminium.
The beam in 5.02 m long, has two pinned suppports, several forces (KN/m - linear distribution) and a few combinations. Calculation is to be made in 2D XZ plane. Everything is ok so far. Calculation and diagrams look ok, but when i perform the steel/alum design i have a problem.
It seams that if the material is steel, the design verification is correct, but when i change the material to Alum, I get the internal axial value NEd = 0 and no buckling verification.
I'm probably doing something wrong....
Attached a picture and the rtd file.
Also I would like to ask what are the the values underlined with green in the picture. some coordinates?
4 REPLIES 4
Artur.Kosakowski
in reply to: jo2ny
Position of the verification point where the ratio is the highest.
Tension force in bar.
Artur Kosakowski
jo2ny
in reply to: Artur.Kosakowski
Got it,
Thank you very much!
Участник
in reply to: jo2ny
Strange no one mentioned that aluminium member should be verified according to EN 1999-1-1 rules not EN 1993-1-1, which, the last time I checked, not implemented in Robot
Can be if sombody decides to run such check in Robot (possibility rather than being told to do this) Smiley Wink
Artur Kosakowski
