Discussion Groups
Robot Structural Analysis
Active Contributor
1 Kudo
Accepted Solution
Steel/Timber Design Module - Results Analysis
241 Views, 2 Replies
07-06-2012 03:29 AM
I was wondering how people use the timber/steel design module?
I can get a long list of elements, telling me which elements are failing and which aren't, but then i can't use that data to highlight the failing members, or even better show a maps on bars type visual showing percentage utilisation of each member. Is this possible?
Thanks!
Product Support
757 Kudos
Re: Steel/Timber Design Module - Results Analysis
07-06-2012 03:44 AM in reply to: PaulGrimes2282
Please check http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Autodesk-Robot-Structural-Analysis-Steel-des... and the attached pictures.
Artur Kosakowski
Active Contributor
1 Kudo
07-06-2012 04:10 AM in reply to: PaulGrimes2282
Thanks! tried searching the forum but didn't find that post...
