Steel/Timber Design Module - Results Analysis
2 REPLIES 2
PaulGrimes2282
552 Views, 2 Replies
I was wondering how people use the timber/steel design module?
I can get a long list of elements, telling me which elements are failing and which aren't, but then i can't use that data to highlight the failing members, or even better show a maps on bars type visual showing percentage utilisation of each member. Is this possible?
Thanks!
2 REPLIES 2
Please check http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Autodesk-Robot-Structural-Analysis-Steel-des... and the attached pictures.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
Thanks! tried searching the forum but didn't find that post...
