Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Steel slederness ratio limit, Lambda, max per Eurocode
4 REPLIES 4
Sangduan
7619 Views, 4 Replies
Dear All,
Does anyone know the equation for calculating Lambda, max per Eurocode?
My section fails global stability check as the section slenderness ratio about z axis,Lambda,z, is larger than Lambda, max value.
I have tried to look for the equation in the code, but I am totally unlucky.
Attached please find the calculation note printed from Robot.
The global stability check in on the last page.
Thank you in advace and appreciate any helps.
Sangduan
4 REPLIES 4
Rafal.Gaweda
in reply to: Sangduan
As it is written, point 6.3.1.2.
Max(Lambda,y/Lambda,max ; Lambda,z/Lambda,max) - means max of calculated slendernesses is found and presented
Lambda,max - from Configuration
Rafal Gaweda
Sangduan
Thank you Rafal for your answer.
Sangduan
Tuctas
  A max value of slenderness is defined only in EC8, 6.7.3 for members of braces (if anyone have seen a similar limitation for slenderness in EC3 it would be helpful for this issue).
  Rafal, the window of configuration that you attached is different than the one that is displayed on me..(?)
Rafal.Gaweda
in reply to: Tuctas
You are right there is no lambda limit in EC3.
You may set it as high as you like.
Different code (norm) polish vs EN
Rafal Gaweda
