I am constructing a model whith steel bars and columns.
However it seems that Robot will not calculate/chech Servicebility limit state in Steel design.
I have defined all parts as bars!
Regards
Make sure you have SLS combinations created and you have deflection or displacements limits check boxes marked to set the limit value in bar types labels assigned to elements of the model.
I se now that many bars are defined as Simple bars. And when I try to change the parameters for this one this comes up:
Is it possible to change every bar in the model to a bar type were limit displacements are checked?
1. Read the message 1 above please
2. Define SLS limits (mark the appropriate check boxes in the design parameters assigned to bars) Mind that you cannot modify the predefined labels as e.g. Simple bar so that you need to change the name too.
