Steel results for bars
5 REPLIES 5
Stilie87
240 Views, 5 Replies
I am constructing a model whith steel bars and columns.
However it seems that Robot will not calculate/chech Servicebility limit state in Steel design.
I have defined all parts as bars!
Regards
5 REPLIES 5
Artur.Kosakowski
in reply to: Stilie87
Make sure you have SLS combinations created and you have deflection or displacements limits check boxes marked to set  the limit value in bar types labels assigned to elements of  the model.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
Stilie87
Here is a link to the Robot-file: http://www.filedropper.com/konstruksjonnts
Stilie87
I se now that many bars are defined as Simple bars. And when I try to change the parameters for this one this comes up:
Is it possible to change every bar in the model to a bar type were limit displacements are checked?
Artur.Kosakowski
1. Read the message 1 above please Smiley Happy
2. Define SLS limits (mark the appropriate check boxes in the design parameters assigned to bars) Mind that you cannot modify the predefined labels as e.g. Simple bar so that you need to change the name too.
Artur Kosakowski
Artur.Kosakowski
Artur Kosakowski
